1984 Ford MUSTANG DRAG RACE CAR
READY TO RACE , consistanly ran in the low 7s in the 1/8 mile with 2 people in the car
Could easly run in the 6's with just the driver
$12,000
CALL 619-994-8187 Ask for Randy or Gus
We raced this at the 1/8 mile stadium drags in San Diego. The drag program was shut down, we totally went through the car
& rebuilt or replaced almost everything & the car has not been on the drag strip since rebuild..... We want to sell this so we can put the money into our salt project. Call me & we can talk
351W Ford V8 , FRESH REBUILD , cylinders 30 over
Keith Black Pistons & Rings
Balance & Polished Rods & Crack
Melling Oil Pump
Double Roller Timing Chain
Schneider race cam & lifters
Edelbrock Aluminum Heads
Edelbrock Intake Manifold
Roller Rockers
Chromemoly Push Rods
Fluiddampaner Balancer
MSD - Mallory Ignition
7qt Oil pan
B&M C4 auto Trans
B&M Converter
Trans cooler
Solid Motor Mounts
Aluminum Trans Mount
9' Ford Rearend with large spool
STRANGE ENG 5.0 Gears
Currie - Racing Axels
Full Roll Cage
Sub-Frame reinforced with box tubing
Eibach Launch Kit
Reinforced struts
Front A-Arms Drilled & plated
Manual steering
Air Lift bags
PSI Bushings
Bilstein Shocks 40/60
Bilsteins struts 90/10
Spin Tech Mufflers
Chromemoly U-Joints
Heavy Duty Drive Shaft
Drive Shaft Loop
Bogart Aluminum Racing Wheels
Mickey Thompson Tires
