midget,
If there is any question AT ALL of proper camshaft timing, PUT A DEGREE WHEEL ON IT AND CHECK TO BE CERTAIN.
NO HYSTERICS, NO HARANGUE, JUST DO WHAT YOU NEED TO BE CERTAIN.
At a minimum, double check TDC using a dial indicator with an extension. If TDC checks out, cams should be OK, if you used the thicker gasket.
The proper tools are in my toolbox @ T&T. Loan out to you for the asking.
And before you reply about "complexity" or "time available" or ? or ?, CONSIDER the "replacement cost" . . . . . .
Jus' sayin' . . . . that: "A dead horse won't run."
Now back to my bottle of 3Floyds Robert the Bruce
This is precisely why 10 minute jobs take all day . . .
One of my best friends - a man who has expertise in engine building I will never achieve, posts up
IN CAPS WITH OVERSIZED TYPE IN ALARMING COLORS and says:
Jus' sayin' . . . . that: "A dead horse won't run."And then punctuates the statement with this:
Oh, good lord . . .
Well, if at some point I had thought I had done it right, I certainly have enough doubt NOW to reconsider my confidence . . .
SO . . .
2022-08-18_11-00-56 by
Chris Conrad, on Flickr
30 degrees ATDC -
2022-08-18_10-59-42 by
Turning through 300 degrees rotation back to zero on the dial indicator gets me . . .
2022-08-18_10-59-19 by
A grand coincidence - the transmission pilot tool is a friction fit into the center of the timing wheel. That saved me 10 minutes looking for refrigerator magnets . . .
As to the cam timing . . .
2022-08-18_12-28-25 by
BULLSEYE!
And as long as I've gone down the rabbit hole, I might as well access my new-found welding skills . . .
2022-08-18_11-06-46 by
So now I can actually put a timing light on it, knowing that the trailing edge of the 7th tooth is TDC.
Trust me, I'm not bitching - I've made enough errors on this build and ducked catastrophe often enough that double checking - and re-checking - has become second nature and expected. And I'm grateful to have Mark's eyes looking over the Cheddar Curtain to help keep this project moving forward.
Thanks, Fordboy!
