Special 'K', krankenshafted . . . . . .OK. Got my first close up inspection of this "engine of the eighties". Interesting, to say the least. Sorry, I did not take the time for photos.
First, and worst, observation was that
ALL the rod bearing oiling is directed from cross-drilled main bearing journals #2 and #4. This is coupled with main bearings grooved on the upper shell only, positions #2, #3, and #4 only.
Think about this, and what it really is. Stumped? It's the oiling setup from the #2 main to the #2/#3 rods, albeit with cross-drilling, from our favorite tractor engine, the BMC!!!!!!! Doubled up to feed 2 sets for a total of 4 rod bearings. Makes you wonder who designed this setup . . . . . . and also if the racing K's in Britain are using modified oiling systems. BTW, as an aside, this crank is heavily worn on the rod journals. Go figure.
Well, no harm done, 'cause Chris wasn't going to be able to use it anyway, because of the stroke.
So, to paraphrase former Bears head coach Dick Jauron's 2002 Quote of the year, "It's not my build, but I'm on that build." Given that, this is what I would do for a crank:
1] E4340 billet crankshaft. 8 counterweights, aerodynamically shaped. Heat treat with Ion-plasma nitride. Dynamically balanced.
2] Reduce stroke to 56mm. (75mm bore = 989.6 cc's 75.5mm bore = 1002.8 cc's)
3] Size/grind rod journals to use race quality bearings, Honda or other.
4] Drill crank for low pressure oiling strategy, ala Nascar Chevy. #1 main feeds #1 rod; #2 main feeds #2 rod; #3 main feeds thrust washers; #4 main feeds #3 rod; and
#5 main feeds #4 rod. This will require grooved bearings or grooving the stock bearings to facilitate the oil feed, as in racing 4 cylinder Fords/Cosworths. No cross-drilling.
edit: Grooving the mains, (1,2,4,5) ala racing Subaru, might be the best option.5] Retain rear hub seal diameter and location to retain stock rear crank seal.
6] Extend rear hub to accommodate engine adaptor plate and BMC transmission. Dimensions/sketch to follow.
7] Machine/grind rear hub extension to mount BMC flywheel with the std BMC bolt/dowel pattern. 3/8ths UNF threads in crank.
8] Retain BMC pilot bushing dimensions in rear hub extension.
9] Retain metric crank snout thread for drive cog compatibility.
x] Possible main journal/main bearing size change, if a suitable fully grooved bearing is found. ? ? ? ? ?
Anything else you can think of Chris?
Numbbrainboy
