Author Topic: Getting ready for Bonneville(rebuild)  (Read 2047606 times)
Offline bvillercr
« Reply #885 on: January 11, 2010, 11:12:23 AM »
I was under the car taking the drive shaft off and thought to myself it sure is nice to working on the car and being able to watch playoff games.
Offline Bville701
« Reply #886 on: January 11, 2010, 10:34:58 PM »
 :-D :cheers:
Ryan LeFevers
Offline bvillercr
« Reply #887 on: January 12, 2010, 12:12:32 AM »
We got our head all welded up and it will join it's twin sometime this week at the head hospital for valve replacement and upgrade. :-D. So we started the 2010 overhall by taking the transmissions out so now the engine compartment is next. :cheers:
Offline robfrey
    • carbinitelsr
« Reply #888 on: January 12, 2010, 09:14:05 PM »
Troy,
What valves will you be using?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline bvillercr
« Reply #889 on: January 12, 2010, 10:48:05 PM »
Manley
Offline bvillercr
« Reply #890 on: January 12, 2010, 11:20:54 PM »
Ok, I'm on my home computer now.  Here is a picture of our repaired head.
We took the head in today and order new Manley valves.  The exhaust will be Inconel and the Intake will be Titanium.  We should have them back in a month, with plenty of time to get other engine components worked on.
Our transmissions in:
Our transmissions out:
Next is to take out the blower plate and the block.
Offline Bville701
« Reply #891 on: January 13, 2010, 12:32:08 AM »
Did a good job on repairing your head.   :cheers:
Ryan LeFevers
Offline bvillercr
« Reply #892 on: January 13, 2010, 10:27:54 AM »
the center cylinder(see picture)spark plug was a little dinged up.  A couple friends did the work, Walt did the welding and Chief did the finish work.  Both from Santa Barbara and both helped in the origional build of the car.  :cheers:
« Reply #893 on: January 13, 2010, 11:01:00 AM »
  All the small pinholes in the same chamber are from a previous repair job [dropped a valve in 03 resulting in a slower record
and chamber looked like hamberger]. The same guys did the repair work Walt Waiton did the welding with his trick welder that adds very little heat and therefore does not require preheating and on recent repair we didn't have to replace the seats. Chief Galbraith did the machining and replaced the seats on the welded up 03 repair on his C@C machine which was not easy because of shape.
Offline bvillercr
« Reply #894 on: January 18, 2010, 09:21:45 PM »
Since our heads are in the shop and that is our main upgrade for the year I wanted to share some pictures of "Chapman Racing Heads" shop.  These guys were recommended by many Bonneville racers and I was givin direction to the shop by Larry Volk.  This shop is very friendly to Bonneville racers during speed week.  The problem we ran into wasn't Chapman Racing, it was the availability to get good valves overnight.  They really got our heads together quick and we got to finish speed week with some amazing runs after we got the engine back together.  Here are a few pictures of Chapman Racing Heads.
Big Mike is the man in charge of the shop and when you call be sure to ask for him.  They also had some pretty impressive customers on their shop board.  I know spelling will be an issue here but here I go, Genalossi and Dutweiller just to name a couple.  There were many other but these two stood out the most. :cheers:
Offline Bville701
« Reply #895 on: January 18, 2010, 09:36:26 PM »
That's a nice looking shop!!!    :cheers:
Ryan LeFevers
« Reply #896 on: January 19, 2010, 09:15:19 AM »
...and seeing the fellow in the photo -- running -- makes a good impression, too.  They don't sit around drinking coffee!
Offline AJR192
« Reply #897 on: January 19, 2010, 09:43:26 AM »
Mike Chapman is for sure no stranger to the salt. I am pretty sure he was involved with Skidmores efforts long ago. And today he is involved with Nish and several others.
Offline bvillercr
« Reply #898 on: January 19, 2010, 07:34:20 PM »
Found a picture of "Big Mike" working on one of our valves.  He is the guy in charge of the shop, the owner is Mike Chapman
Offline krusty
« Reply #899 on: January 19, 2010, 08:26:52 PM »
In 2008 we had a "slight overrev" on our 23* Pontiac heads. I pulled them, got to Chapman at 4pm, and was on my way back to Wendover @ 9pm with 16 new valves (needed only 15!), seats recut, etc. Big Mike is the MAN! He "borrowed" some new Manleys from another customer's build, did the same with some pedestal shims, and got us back on track. Absolutely the greatest service.    vic
