Author Topic: Getting ready for Bonneville(rebuild)  (Read 2047607 times)
Offline bvillercr
« Reply #765 on: August 10, 2009, 08:17:30 PM »
Hey Bob Ellis, Augie says hi but your a sheep shagger.   :-D. They kissed the piston with the valve and burnt a small spot in the piston.  They are lapping the valves in and they are going to go for anyway.  They said if they are going home it might as well be in big pieces rather than small ones. :cheers:
Offline bvillercr
« Reply #766 on: August 11, 2009, 02:59:48 PM »
We are heading to the salt now with a set of reworked heads, we will run in the morning.  :cheers:
Offline Cajun Kid
« Reply #767 on: August 11, 2009, 03:51:47 PM »
B'ville,,,  wow lots of work in short order,,,,
Good luck, GO FAST,,, don't hurt that awesome motor and BE SAFE...
Keep the reports coming....
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline bvillercr
« Reply #768 on: August 11, 2009, 10:32:33 PM »
We fired her up and look out, she sounds crisp.  Can't wait till record run are over. :cheers:
Offline wolcottjl
« Reply #769 on: August 12, 2009, 12:07:59 AM »
GOOD LUCK!  Everyone is pulling for you!
Joel Wolcott
Moving to 2 wheels in 2010
Offline bvillercr
« Reply #770 on: August 12, 2009, 02:29:50 PM »
Just made a pass and went 268 in the 1/4 and shut down before the mile.  We went 269 in mile and blew off the blower intake to the manifold.  Were in impound now. :cheers:
« Reply #771 on: August 12, 2009, 04:20:00 PM »
Nice !!   :cheers:
Offline bvillercr
« Reply #772 on: August 12, 2009, 07:03:53 PM »
A little more info on todays run.  We blew off the blower tube at the elbow before the intake, also we blew anti seize all over the distributor and valve cover because some of the manifold bolts came loose.  We made a 3/4 metal strap to hold the elbow and the blower tube together so we don't have the same problem.  We are heading out of impound for the 2 club dinner. Will report more after record runs. :cheers:
« Last Edit: August 12, 2009, 07:11:14 PM by bvillercr »
Offline wolcottjl
« Reply #773 on: August 12, 2009, 11:14:26 PM »
Not a bad place to be.   :cheers:
Joel Wolcott
Offline bvillercr
« Reply #774 on: August 13, 2009, 11:34:15 AM »
Dad spun at the half mile so we need to requalify.  Yesterday he ran without turning on the inter cooler today the intake temp was 50 degrees, just a bit more power than expected.
Offline bvillercr
« Reply #775 on: August 13, 2009, 06:44:02 PM »
We requalified for records run again, we ran 267 in the 1/4 and then we had two welds brake on two different blower tubes and shut down before the mile and still went 285 in the first mile.  We were tacking 312 but stuff happens and we sunk all the valves and don't know why so we are done for this year.  There is no door slammer this year that has gone faster than us or even faster in the third mile.  The only doorslammer that may have gone faster in the first mile is the Leggit firebird.  Were happy with the speed but no record this year.  :cheers:
« Last Edit: August 14, 2009, 01:21:53 PM by bvillercr »
Offline Cajun Kid
« Reply #776 on: August 13, 2009, 08:36:58 PM »
B'ville,,,, man GREAT  effort,, way to hang in there and try and try and try again,,, awesome speeds..
Thanks for all the build posts and the updates... I know  we where all pulling for you,,,
Take care,,, safe travels home.
Charles
OHIO
B/CGALT, C/CGALT
« Reply #777 on: August 14, 2009, 12:58:56 PM »
HEY PALS, it was marvelous to see you.
Hang in there.
See you at Gas Up?
Offline bvillercr
« Reply #778 on: August 15, 2009, 11:27:40 AM »
Thanks everyone who replied, and Freud it was great to see you again too.  We will be home later today and I will start working on all the videos soon.   :cheers:
« Reply #779 on: August 15, 2009, 11:30:18 AM »
Here's the only photo I got of you -- at the 200 MPH Club banquet.  It was great to see you all week, thrashing and running and everything else.  Congratulations!
