Author Topic: Getting ready for Bonneville(rebuild)  (Read 2046698 times)
« Reply #2580 on: June 22, 2021, 06:54:55 PM »
 Picked up the block today, bored ,honed, rings fitted and line honed.  Cam was roughed out and waiting to be finished as of Monday. Rods ? 5 weeks Friday call then.
Offline revolutionary
« Reply #2581 on: August 10, 2021, 05:07:13 PM »
Congrats on qualifying at 292 today!!!
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
« Reply #2582 on: August 10, 2021, 07:22:07 PM »
 :cheers: :clap
« Reply #2583 on: August 12, 2021, 11:49:14 AM »
Sounds like you lost a cylinder?
Breaking Wind #9614
« Reply #2584 on: August 16, 2021, 06:54:56 PM »
 Yep....0 compression in #1 cyl all cyl had 75 lbs before run normally 100 lbs. squirted oil into cyls
this morning and pressure came up to 90 to 100 lbs even 50 in #1, like rings never seated.
 Different oil but mineral base Find out more at tear down next Sat.
  Engine way down on power compared to 294 run in 2010
  Lots of things wrong on Troy's 292 mph run oil pressure going down manifold temp rising suddenly to 200 normally 130 and fuel pressure down causing a cough and Troy shutting down.
 Fuel problem may have been because of only 4 inches in tank. We only made one run of 1 1/2
miles prior but to many warm ups it seems. Bought 15 gals, damn gas hog. Oil was down in tank
 like pump not sucking but I think problem is in valley were we advised to restrict oil by gluing
plates in and drilling a 1/4 inch hole lots of room for oil up there. Big drain lines in valve cover to pan below splash plate. intercooler pump was working this morning maybe an ice block?
« Reply #2585 on: November 02, 2021, 01:10:14 AM »
  Ordered 8 new Bill Miller pistons and taking to him about oil pressure and watching his video on his site
   I purchased a System One gear pump which shows more volume, pressure and vacuum from oil pam
than our G rotor pump that his video shows cavitation at 4500 rpm.
    Sunday we made up oil lines for new pump. Waiting for pistons and boring for 2 new sleeves on block.
    Every bodies behind so no Nov El Mirage.
« Reply #2586 on: November 16, 2021, 01:40:30 AM »
  Last AUG Bville we had high intake manifold temps after intercooler normally 130 or less but 200  So we took the tank out checked for blockage ECT cleaned the bottom and noticed the water lines not routed in the best way. Two 1'' hoses from 55 cal min pump go to big ass intercooler and two back to front of tank.' We made the tank with 3 bulkheads with 3 Marine portals for ice. Water from intercooler goes into 1st section under i'' raised bulkhead into 2nd section and flows over top to last section being cooled the whole way. Well for some reason we can't remember, one hose was routed to last section. We did have an overflow hose for that last section at one time [OLD VIDEO :-P]  maybe a quick fix.
 Pump works great and intercooler flows well so hoping that was the problem.  BUT maybe sender not
 right :?
« Reply #2587 on: March 18, 2022, 05:59:26 PM »
    Engine is together except for 1 head and manifold should finish tomorrow also flywheel clutch and bellhousing.
    New pistons and rings  2 new sleeves honed with 280 grit instead of a too fine of a hone last year, all new cleavite bearings
      Valves lapped with new 375 lb springs a SYSTEM one oil pump with up to 25o lbs + pressure and intercooler
      return line routed correctly. We also modified the fuel return line that dumps in fuel tank with a longer hoes that goes to bottom of tank and curves to the front to make sure of no aeration.
    One other thing we did was a better intake port alignment on the heads that was discovered to late last year to change.
  SO were hoping for the same hp and track as we had when we were timed at 294 mph in the 1st mile.
« Last Edit: March 18, 2022, 06:13:51 PM by jl222 »
« Reply #2588 on: April 07, 2022, 04:44:09 PM »
  Engine is in, all together ready to fire except for gas, oil and water but waiting until after car show Sat and new graphics next week
« Reply #2589 on: April 07, 2022, 05:19:54 PM »
Pictures?
« Reply #2590 on: April 07, 2022, 07:22:57 PM »
Pictures?
               :-D   I was going to say, maybe some pics from Troy via Slim
« Last Edit: April 07, 2022, 07:28:34 PM by jl222 »
Offline bvillercr
« Reply #2591 on: April 07, 2022, 10:33:32 PM »
Trying to figure our copy and paste options.
https://www.instagram.com/p/CcCAz_RpdgZ/?igshid=YmMyMTA2M2Y=
Offline bvillercr
« Reply #2592 on: April 15, 2022, 10:49:03 PM »
Frank Silva from Got Salt team did a great job designing our first ever race shirt for our team and these will be available at Speedweek 22.  We have some new graphics on the Camaro which is a throw back to our original graphics, but this is a little different.
https://www.instagram.com/p/CcY3CzNPSfd/?igshid=YmMyMTA2M2Y=
« Reply #2593 on: April 15, 2022, 11:11:29 PM »
Well ya know what happens when you put a speed on a shirt...
Yep you go faster and obsolete the shirt....
Good luck, see ya on the salt
« Reply #2594 on: June 19, 2022, 12:46:51 AM »
  Link above shows engine running and throttle blip.
   We installed a new oil pump and couldn't get oil pressure and clutch wasn't releasing. So out with the engine
thinking maybe an oil plug was left out. Not so, hooked up oil lines to filter and dry sump spun engine to observe
0illig to crank and rods, oil all over the place and still no pressure. Figured out as new pump routs oil back to dry
sump verses old goes back to pump and has pressure, the new from the filter ( where we take oil pressure from)
and to dry sump is an open line and no pressure. Now taking pressure off pump. So late smart. Fixed O ring in clutch throw-out  and now HAPPY.
   New rear FAT tires coming and fixing a clutch hold down bar and we are ready for over 300 at Bville.
 NOw link not working with out an account
« Last Edit: June 19, 2022, 01:06:53 AM by jl222 »
