Author Topic: Getting ready for Bonneville(rebuild)  (Read 2046680 times)
« Reply #2520 on: November 25, 2019, 06:43:34 PM »
After replacing all the door and hatch "gaskets", even taping the doors and hatch shut, here's how Steve Batchelor solved the dust problem . . .
 Thanks again Jim... do you know where Steve found that scoop?
 Anyone know where to find small scoops?
 Ordered new door weather stripping today From RockAuto.com.
« Last Edit: November 25, 2019, 06:45:20 PM by jl222 »
« Reply #2521 on: November 25, 2019, 07:35:14 PM »
He made it.  I'll see if I can find a better picture of it.
I think it's all about equalizing the pressure in and out.  With our roadster, I had a windshield the first time I ran at El Mirage.  The dust came up to the top of the "glass" and obscured my vision. I didn't run it again.  The dust doesn't do what we would suppose it would.
« Last Edit: November 25, 2019, 07:38:12 PM by Stan Back »
« Reply #2522 on: November 25, 2019, 07:58:57 PM »
This was about 1990 and I'd driven the roadster up from Berdoo to spectate.  The scoop looks to be configured like an early Pro Stock one.  I'm thinking that it's more important in its location than its configuration.  I only drove the car once -- at Bonneville -- and that doesn't count.  Sure was loud sitting back in there with all that horsepower rattling the tin.  I can barely drive, but never screwed up on that one.  The car was a gem.
« Last Edit: November 25, 2019, 08:00:43 PM by Stan Back »
« Reply #2523 on: February 03, 2020, 02:37:56 PM »
  Last Sat we installed an air scoop in front windshield. Used a 2in wide 1/4 cup stainless measuring cup, cut the bottom and handle off, holesawed the wndow and finished to size with the air tool .Glued it in front and back with clear silicone.
 Still need to get some 3m weatherstrip glue or similar [ used to call it Elephant snot back in the early seventies when we put it on our motorcycle bolt threads to keep from coming loose when racing the desert, it was yellow :-)] for the new door weathersriping .
                    jl222
Offline Happy Pappy
« Reply #2524 on: February 03, 2020, 08:22:10 PM »
LOL... Gorilla Snot. We used it to glue the hand grips on the dirt bike handle bars. Messy stuff for sure.
Chris
Chris Campbell
2017 #203 G/GR El mirage record 150.771
2020 #62 C/AIR El Mirage record 180.828
6/21 #62 C/AIR El Mirage record 185.488
9/21 #62 C/AIR El Mirage record 194.450
« Reply #2525 on: February 03, 2020, 08:42:40 PM »
We used the term Gorilla Snot too. It's actually weather strip adhesive. We always used 3M brand because their products usually work as designed even if we, as racers, seem to find other uses for them.  :-D :-D :-D
« Reply #2526 on: February 03, 2020, 09:20:03 PM »
yea, we called that stuff yellow death... anything you put it on was not coming off... including you...
Oh, John, without pictures it never happened  :?   :cheers:
« Reply #2527 on: March 14, 2020, 08:04:57 PM »
  Major improvement to shop today. 10,000 lb 2 post car lift installed. lifts up to 75 in.
  No more laying on back to check rod bearings ECT.
  Picked up hoist in Hayward Ca last week and had 2nd thoughts about installing ourselves.
   600 bucks to install and glad I had it done, saved a lot of cussing.
« Reply #2528 on: March 29, 2020, 03:37:30 PM »
  heavy duty 220 volt extension cord finally arrived and we lifted the Camaro for the 1st  time.  Really going to make things easier. :-D
« Last Edit: March 29, 2020, 03:39:26 PM by jl222 »
« Reply #2529 on: April 04, 2020, 01:01:21 AM »
Every few pages I like to put up videos of our runs so if people want to find them they can locate them a little easier.  These are some of our better videos.
     These are in 2008
http://www.youtube.com/watch?v=mHUEA-pScY8
http://www.youtube.com/watch?v=Udo7XM472Qk
                 2009
http://www.youtube.com/watch?v=55XA0vrNNj0
                 2010
http://www.youtube.com/watch?v=yxkEtJ1b6AI
http://www.youtube.com/watch?v=kLG0JFzazrs
 More from the past
 Something to watch while quarantined  :-D
« Reply #2530 on: April 04, 2020, 02:49:29 PM »
John ?
Where did the water come from in the last few seconds of the very last video you posted?
Stan
« Reply #2531 on: April 05, 2020, 12:58:17 PM »
  Jim... from the vent hose from the intercooler tank. it now has a catch can :roll:
« Reply #2532 on: May 12, 2020, 11:16:07 AM »
  WOW a million views :cheers:
 Car is ready for Bville except for new fat tires, ordering soon
Offline bvillercr
« Reply #2533 on: May 12, 2020, 10:56:37 PM »
We eliminated the hose all together and blocked it off at the tank.  It is time to fire it up soon!!
« Reply #2534 on: June 08, 2020, 07:22:31 PM »
 New fat boy tires arrived Fri, mounted and balanced today.
 We had a problem with an air dump valve causing slow shifts and Scotty Owens is sending two today.
