Blessed are those that post pictures of cool eye candy. Thanks
Not so sure about cool
We have had hell the last few weeks, after firing up we discovered no oil in rocker shafts that oil the rockers and pushrods.
Aftter removing the heads and checking cam bearing to see if bearing had spun and was blocking oiling holes [it was ok]
and pumping oil up through block, we drilled out the KB oiler holes in the rocker stands that supply oil to the shafts.
kB holes were half the size of stock stands.
Fired back up and problem solved , called it a night.
Next day, fired it up and only firing on one side
Just bought a new EFI Y connector for same problem a while ago.
Spray cleaned connectors, checked voltage, and ran good, Warmed her up and set the valves. Started up again and ran
on one side only. ordered another EFI Y harness. Delivered Thur.
Justin our EFI expert came out last night to put 294 mph bville tune in EFI from laptop, installed new harness and same old thing, firing on one side only, couldn't fix it after checking and cleaning all connectors. Injectors show voltage on hot wire on bank not running?
Troy's been talking to tech and it could be an ignition signal problem and I talked to fast about a new box and they said
I could check my box on another car with a fast unit. Justin has been working on a car with a fast unit. call into him waiting on answer.
If that's not enough my tow truck needs a new sensor
If I need a new box FAST can ship next day to Wendover
